Suneel Posted September 13, 2006 Report Posted September 13, 2006 Hi all, I am facing a problem while creating the control reference for an image control. The error is "Plug In 'Image':control requires an external library". Thanks and regards, Bhaskar Reddy.k Quote
Born2Wire Posted September 13, 2006 Report Posted September 13, 2006 Hi Suneel, I had this same problem with IMAQ picture controls. I think the problem is that the IMAQ control is itself a reference. So when you try to make a reference to it, you are trying to make a reference to a reference. This apparently makes LabVIEW unhappy. When I got that far in my thinking I just re-wrote my code to pass the IMAQ wire everywhere I needed it. I suppose if you really really wanted to make a reference to it, you could try a generic control reference instead of a specific IMAQ control reference. WHat is it that you are trying to do by makeing the reference? Hi all,I am facing a problem while creating the control reference for an image control. The error is "Plug In 'Image':control requires an external library". Thanks and regards, Bhaskar Reddy.k Quote
