Michael Aivaliotis Posted September 14, 2006 Report Posted September 14, 2006 Original Post: http://forums.ni.com/ni/board/message?boar...ssage.id=204785 hello, i work with thr debugger for the first time. my problem is that i havn't got a blockdiagramm to set probes or breakpoints. or is this not possible in labview? i startet my executable and connected my application. there are two windows. one window is remotes the other, but there's no blockdiagramm is there any way to open a blockdiagramm? markus confirmed Response:Markus, I tested out your theory and found that with a custom run-time menu CTRL-E gets ignored while the VI is running in the EXE as does the menu item Show Diagram. The only way I found to do it is to also enable 'Wait for debugger on launch' in the EXE builder. This will cause the EXE to open but not run any VIs until you press the run button or connect via the Operate>Debug Application and then press Run this will give you the chance to Connect, show the diagram, then click the run button. I'll report this so it gets fixed. Kennon Quote
