Thomas Posted September 14, 2006 Report Posted September 14, 2006 Hi, I have a problem with the watchdog using a FP-1000 with serial connection (RS232). The watchdog is set to 5000 ms. I read all AI channels (16) every 100 ms in a while loop, so I should be far away from the watchdog timeout. However, from time to time the watchdog resets all outputs to zero - sometimes a few minutes after application start, sometimes a few days after application start. Has anybody made similar experience using the watchdog? Any idea what could be the reason for? Thanks in advance. Thomas Quote
