Disable "Run when opened" in Application Builder 8.2
I just have switched to LabView 8.2 and encountered a prolem.
I want to make an standalone executable.
For some reason even when I deactivate the "Run when opened" option
in the Build Specification Settings (Source File Settings) my executable
always starts immediately.
In Labview I did not have that problem, when I started the exectuable
(without "run when opened" activated) and I first had to click on the start button.
Am I missing some point. Can somebody give me a hint, why the generated
EXE always automatically starts even if "Run when opened" deactivated?
Thanks for your hints in advance!
Stefan
Why wouldn't you want your application to start when running in executable mode? If you don't want something to happen until the user clicks a button (sounds like what you're after) the most appropriate method would be to include event handling in your application...
