David Wisti Posted September 29, 2006 Report Share Posted September 29, 2006 The file open function behaves differently when the "operation" input is a control. See attached v8.01 example vi. Not sure if this is a bug or expected behavior. It sure wasn't what I was expecting and is not documented in the help files. The file open function is blocked by the file dialog express vi if a control is used as the operation input. Download File:post-319-1159549716.vi Quote Link to comment
Jacemdom Posted September 29, 2006 Report Share Posted September 29, 2006 The file open function behaves differently when the "operation" input is a control. See attached v8.01 example vi. Not sure if this is a bug or expected behavior. It sure wasn't what I was expecting and is not documented in the help files. The file open function is blocked by the file dialog express vi if a control is used as the operation input.Download File:post-319-1159549716.vi Looks like a thread issue...the loop with the control on the UI must end up in the same queue of execution... Quote Link to comment
