Lee Robertson Posted October 12, 2006 Report Posted October 12, 2006 All, I have seen this discussed before but now I can't find it -- sorry for the new topic. I need a way to programmatically determine the number of cases in a case structure. I don't need to know the names or anything, just the number. The reason I need this is to fix an ugly code maintenance problem we have been experiencing. --Lee Quote
jaegen Posted October 12, 2006 Report Posted October 12, 2006 Lee Robertson said: All,I have seen this discussed before but now I can't find it -- sorry for the new topic. I need a way to programmatically determine the number of cases in a case structure. I don't need to know the names or anything, just the number. The reason I need this is to fix an ugly code maintenance problem we have been experiencing. --Lee Lee, 1. If you haven't already, check out this forum, and especially Michael's post that's pinned at the top. 2. There are a few "CaseSelector" class properties which return an array with one element per case. See the attached VI for one example. Jaegen Download File:post-932-1160670604.vi Quote
Mike Ashe Posted October 12, 2006 Report Posted October 12, 2006 Specifically, you want this topic: Case Structure - Is it possible ... The second post should have the "Select-A-Case" zip file which will do and show all sorts of things with cases. Nice toy to have around, even if you don't need all of it right now. Quote
