t2rock Posted October 14, 2006 Report Share Posted October 14, 2006 i'm a student that works on a porject that required to send email using labview. I'm now using labview7. I try to send email using the E-Mail notification VI from the labview example.I enter the mail sever name and the recipients and run the VI. At the end it comes out error code : Error 16500 occurred at 500 2.0.0 'MIME-VERSION: 1.0': command not understood. can someone here tell me wat's the problem with it. Quote Link to comment
Chris Davis Posted October 15, 2006 Report Share Posted October 15, 2006 i'm a student that works on a porject that required to send email using labview. I'm now using labview7. I try to send email using the E-Mail notification VI from the labview example.I enter the mail sever name and the recipients and run the VI. At the end it comes out error code : Error 16500 occurred at 500 2.0.0 'MIME-VERSION: 1.0': command not understood.can someone here tell me wat's the problem with it. I haven't used the VIs you are looking at, but you might read through this post to see if you want to look at this solution as another way of accomplishing the same task. I have downloaded this VI, but I haven't tried it yet, so YMMV. :thumbup: Quote Link to comment
