vhdl Posted October 16, 2006 Report Posted October 16, 2006 Hi all, I have a problem with the ActiveX container on my front panel. Whenever I place it on a front panel and I try to insert an ActiveX object by selecting it LabVIEW crashes. (I am using LabVIEW 8.01 - LabVIEW 8.0 had the same problem). Anyone has a solution for this problem? I don't want to install LabVIEW again on my computer, when I try on other computers in my company it works fine there. Thanks for your help. Quote
crelf Posted October 16, 2006 Report Posted October 16, 2006 I have a problem with the ActiveX container on my front panel.Whenever I place it on a front panel and I try to insert an ActiveX object by selecting it LabVIEW crashes. Is it only happening on a particular object? If so, which one? If it's not a standard Windows object, can you upload it for us to look at? Quote
vhdl Posted October 16, 2006 Author Report Posted October 16, 2006 It is happening on all the objects, the strange part is: when I download an example of ActiveX from the NI website it seems to work; but when I would change the object in the ActiveX container LabVIEW crashes too... Quote
vhdl Posted October 17, 2006 Author Report Posted October 17, 2006 When I try to put a Windows Media Player control or a webbrowser control on my vi frontpanel I get the message in red letters: control could not be loaded. I also can't use the .NET container this gives also problems.... When I download samples of ActiveX vi's they all work, when I try to put another object in the ActiveX container it doesn't work anymore!!! So I cannot make changes in the ActiveX containers of downloaded samples... Quote
