LabVIEW crashes when calling ActiveX object
Hi all,
I have a problem with the ActiveX container on my front panel.
Whenever I place it on a front panel and I try to insert an ActiveX object by selecting it LabVIEW crashes. (I am using LabVIEW 8.01 - LabVIEW 8.0 had the same problem).
Anyone has a solution for this problem?
I don't want to install LabVIEW again on my computer, when I try on other computers in my company it works fine there.
Thanks for your help.
Is it only happening on a particular object? If so, which one? If it's not a standard Windows object, can you upload it for us to look at?
When I try to put a Windows Media Player control or a webbrowser control on my vi frontpanel I get the message in red letters: control could not be loaded.
I also can't use the .NET container this gives also problems....
When I download samples of ActiveX vi's they all work, when I try to put another object in the ActiveX container it doesn't work anymore!!!
So I cannot make changes in the ActiveX containers of downloaded samples...
