Stack Plots Waveform Graph not possible?
heiko
i am displaying multiple measures in a waveform graph (WG) using a cluster with t0, dt and a 2D array. Cause the scale of the measures is different i wanted to switch to this stacked display the waveform chart is capable of. Now it looks that WG does not support this. Does anyone now an elegant solution other than manually scaling the graphs?
cheers heiko
You can use a second y-axis.
Right click on the y-axis. Select Duplicate Scale. Right click on the new axis and select Swap Sides (if you like).
Right click the plots in the plot legend and choose the y-axis that you want that plot to be associated with.
