[CR] Vi, Vit, Ctl Icon and Description Editor
This is a nice tool. It will help the LAVA members edit their VI's before submission to the Code Repository! Hey, we're dogfooding :o .
Some issues and suggestions:
  • When I click load directory, the second time, it doesn't remember my previous folder I navigated too. It would be nice if it took me to where I was before.
  • During navigation of the tree I got a pop-up error. I forgot to get a screen capture. The message said something about not being able to find the file: VI Path: \\windy1\wsw\LabVIEW\SW\Projekte\DIVERSES\ICON-Editor\SERVER-ICON-Editor.vi
  • During text entry, there is no limit of the body fields. This causes the Icon to compress when too much text is entered. I recommend an autocalculation and a text entry hardstop if too long.
    post-2-1161834203.png?width=400
  • When editing thr VI description, it would be nice to be able to resize the window.
  • When editing thr VI description, it would be nice to have a button that when you select a group of text you click a button "Bold" and it would wrap the text in <B></B> tags automatically.
  • The Reload old Icon does not work if you edit the icon, save it then doubleclick the VI to open it. You cannot reload old icon anymore. It's gone?
  • It would be nice to have the ability to apply the colorset to a group of VI's at once.
That's it for now. Keep up the excellent work!
  • 2 weeks later...
Hello Michael
Thanks for your suggestions.
Update: Following suggestions are implemented and the bug with the tree control is solved (Version 1.7)
* During navigation of the tree I got a pop-up error. I forgot to get a screen capture. The message said something about not being able to find the file: VI Path: \\windy1\wsw\LabVIEW\SW\Projekte\DIVERSES\ICON-Editor\SERVER-ICON-Editor.vi
* During text entry, there is no limit of the body fields. This causes the Icon to compress when too much text is entered. I recommend an autocalculation and a text entry hardstop if too long.
* When editing thr VI description, it would be nice to be able to resize the window.
* When editing thr VI description, it would be nice to have a button that when you select a group of text you click a button "Bold" and it would wrap the text in <B></B> tags automatically.
*When I click load directory, the second time, it doesn't remember my previous folder I navigated too. It would be nice if it took me to where I was before.
=> In our company we call the Icon editor over a vi-server call (SERVER-ICON-Editor.vi) from another vi from "TOOLS" so I can modify and update the ICON-Editor and I don't need to distribute it to all developers (Windows & Linux). Because of that, I don't like to save the last path, since it is not useful for us.
=>When I start the ICON Editor, the "startfolder" is always the folder where I have saved the last new vi. I think this is very useful because you usually have to edit only new Vi-ICONS...
=>But I could implement a "LAVA Edition"...
*The Reload old Icon does not work if you edit the icon, save it then doubleclick the VI to open it. You cannot reload old icon anymore. It's gone?
=> The reload old Icon works only as long as you don't click again in the tree control...
*It would be nice to have the ability to apply the colorset to a group of VI's at once.
=>Maybe in future...
=>another thing for future is an option to copy a part of an ICON (Header /Body) and paste it to the current vi...
cheers :beer:
  • 3 weeks later...
The New ICON Editor 1.7 is now available!
New features:
"automatic text cutter" => The ICON text will automatically cutted if there are to much characters :thumbup:
You can automatically add and remove Tags (<B> </B>) in the Description Editor. (The text between the Tags will be written BOLD) :thumbup:
An Indicator is blinking and the cursor is set to busy while the tree control is updated
Bug solved with old tree control paths
Frontpannel optimiced fot 1024*768 screen
Open Frontpannel and Blockdiagramm by right-click to the Tree CTL or LLB-Content
Automatically generate a Description with Username, Date, CTL Inputs and Outputs if they are connected to the connector pane (including their description)
Howto make a automatic Description?
1. Start the Icon Editor
2. Open a Directory
3. Select a Vi
post-1396-1164354624.jpg?width=400
4. Click Edit Documentation
post-1396-1164354540.jpg?width=400
5. Click New Documentation
=> There will be a new Documentation generated based on the description.txt File located beside the ICON.llb File
Example:
RUAG Aerospace
Center Aerodynamics
CH-6032 Emmen
www.ruag.com
Version: 0.0
Date: <DATE> (will be replaced with the actual date )
State: In Progress / Finished
Developer: <NAME> (will be replaced with the current LabVIEW Username)
FUNCTION
(Explain the function of the vi)
<Input>
Between these thags it copies all Vi- Input CTL which are connected to the connector pane
</Input>
<Output>
Between these thags it copies all Vi- Output CTL which are connected to the connector pane
</Output>
COMMANDS
(Expain here the commands of the vi (INIT: Initialize...; START: ....)
PRE-CONDITIONS
(Place here the Pre-Conditions of the vi)
POST-CONDITIONS
(Place here the Post-Conditions of the vi)
ERROR HANDLING
(Place here information about the Error Handling (This vi will executed/not executed if error in has an error)...
post-1396-1164354817.jpg?width=400
NOTE: Do not Remove the <Input></Input><Output></Output> Tags!!
If you have changed some connectors etc. just click Update CTL Description.
If you have an old description you can add the <Input></Input><Output></Output> Tags by selecting the place and then by right Click (add Input Tags / add Output Tags) In the current version you need always all tags...
