Plot Area Maximum Size?
It seems that plot area size has a maximum size beyond which the grid lines stop appearing:
----E.g: if you make an X-Y plot up to 50000 units in height, the horizontal grid lines will disappear at some point when you scroll to near the bootom of the chart.
----Does anyone know if this has a fix? I need these long charts because I end-up printing the front panel as a strip chart for a lithology profile.
post-1804-1163043498.png?width=400
Of the top of my head, there's probably some way you could string together 2 (or more) charts. Just line them up properly, make the appropriate parts transparent, and workout how to set the scale ranges.
Jaegen
Jaegen:
Thanks for your insightful suggestion. I tried your suggestion and determined that a new plot, however small, will be affected by the same problem as long as it is located beyond the position where grid lines disapear. I called NI today and they think that it is bug in LabVIEW which should be fixed.
... I will confirm this tomorrow.
post-1804-1163125498.png?width=400
