Donald Posted November 14, 2006 Report Posted November 14, 2006 Since LabVIEW 8 it is possible to remotely debug a labview executable or dll on a client computer over tcp/ip. It seems to be a fantastic feature that is not used by a lot of LV developers (nearly no Google results). Does anyone has an idea if you need to configure DCOM or Firewall ports for this (cfr. OPC server)? I have a headless PC and I lost the remote debugging access (no application enumerated on the host)... I suspect a DCOM problem created by Windows update. Installing LV8.2 is not an option on a flash disk. Quote
Stetson McGraw Posted November 14, 2006 Report Posted November 14, 2006 If you're seeing the message "No debuggable applications or runtime libraries found", it means you were able to query the target machine for debuggable applications, but the application's debug server did not start successfully. In this case, I would suggest restarting the application. However, if you get the text message "Failed to lookup debuggable applications or shared libraries", it could mean two things. 1. The National Instruments Service Locator is not started. The Service Locator is used by debuggable applications and other NI services to register their pertinent information for other client applications to look up. You can check and start the Service Locator manually by going to the command prompt and entering "net start nisvcloc". You will need to restart your application after this to make sure it registers with the Service Locator. 2. If after step 1, you see the message "The requested service has already been started", it means the Service Locator was running fine, but the firewall blocked the service locator from opening its listen port. You can configure your firewall to open the port 3580. It is likely that you will also need to configure your firewall to always allow your built application to open any port it needs to allow debug connections. Quote
Donald Posted November 15, 2006 Author Report Posted November 15, 2006 THX for the very detailed info, I'm going to test your recommendations on monday. Quote
Donald Posted December 8, 2006 Author Report Posted December 8, 2006 Hello LabVIEW developers, LabVIEW remote debugging is working again. Adding port 3580 as 'LabVIEW Debugger' to the firewall's exeception list solved the problem (disabling the firewall was NOT an option as this system is connected on the web). THX for the info Quote
