bjarket Posted November 14, 2006 Report Share Posted November 14, 2006 Hi! I'm building an executable which is to be distributed on a number of different machines. The top-level VI includes a number of Express VIs with channels to a connected DAQ-pad. My worries is about the configurability of the channels when the executable has been build - if another computer has registered the DAQ-pad with a different name (e.g. "Dev2") I suppose I won't be able to run the executable? Any suggestions for a solution? I don't see any input parameters on the Express VIs that allows for changing the device name at run-time... Quote Link to comment
lraynal Posted November 14, 2006 Report Share Posted November 14, 2006 That's only a clue to try (not sure if it's enough...): Check to save/export the MAX configuration (usually configData.nce) And load this configuration at the start of your software. Quote Link to comment
Mellroth Posted November 14, 2006 Report Share Posted November 14, 2006 ...My worries is about the configurability of the channels when the executable has been build - if another computer has registered the DAQ-pad with a different name (e.g. "Dev2") I suppose I won't be able to run the executable?... If you define channels in MAX, and then use these channel names in your application you should be safe. If you have to exchange a device (or rename), you only have to update the channel config in MAX. I haven't acually used the express VIs, but as it works for the DAQmx I suppose it will work for express VIs as well. /J Quote Link to comment
Chris Davis Posted November 14, 2006 Report Share Posted November 14, 2006 One suggestion. Take a look at the code behind the express VI you are using. Right-click on the express VI and click on "Open Front Panel". **Warning: You won't be able to edit this express VI as an express VI anymore once you do this, so you might want to make a copy of it before you open its front panel.** Once you have the express VI open, you will see a constant listing of the channels that you use in the express VI. Make this constant into a control, and make the "Dev#" part of the string controlable by your program. There are also DAQmx routines that will list all of the avaliable devices on your machine, and exactly what card they are before you try to use them. Quote Link to comment
bjarket Posted November 15, 2006 Author Report Share Posted November 15, 2006 Thanks for the answers! I'll try to add a control to the Express VI as suggested. Best Regards Bjarke Quote Link to comment
