bigl00z3 Posted November 16, 2006 Report Posted November 16, 2006 I'm trying to create a simple data aquisition VI with 8 imputs. I've used the Producer/Consumer Design Pattern (Data) template. In my producer loop I'm writing the signals to a file. In the consumer loop I'm trying to display the values of the differents signals on my interface. I'm trying to access one of the element of a Variant data set from the queue. The Variant Data set has the folllowing structure: <Dynamic Data {[8] (<Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>, <Waveform(DBL) {...}>)}> I've tried to use "Variant to Data" but I can't find a way to set the correct type. How can I "split" it so I can display the values on my Interface? Is there an easier way to do it? It may seem logical, but I'm new to Labview... so excuse me for "stupid" questions... bigl00z3 Download File:post-6798-1163665036.zip Quote
Mellroth Posted November 16, 2006 Report Posted November 16, 2006 I've tried to use "Variant to Data" but I can't find a way to set the correct type.How can I "split" it so I can display the values on my Interface? Is there an easier way to do it? It may seem logical, but I'm new to Labview... so excuse me for "stupid" questions... bigl00z3 Hi, Do you really need to pass the dynamic data in the queue? If not, then just feed the queue with the DBL-array you get from the "Convert From Dynamic Data" node. In the lower loop, set the array constant to an array of DBL (instead of U32) and use this in the "Variant To Data" node. Good luck! /J Quote
bigl00z3 Posted November 16, 2006 Author Report Posted November 16, 2006 Hi,Do you really need to pass the dynamic data in the queue? If not, then just feed the queue with the DBL-array you get from the "Convert From Dynamic Data" node. In the lower loop, set the array constant to an array of DBL (instead of U32) and use this in the "Variant To Data" node. Good luck! /J Thanks a lot, You were right, that fixed our problem. We can now start aquiring our data.... bigl00z3 Quote
Mellroth Posted November 16, 2006 Report Posted November 16, 2006 Thanks a lot, You're welcome /J Quote
