Chris Davis Posted November 22, 2006 Report Posted November 22, 2006 I'm working on a new scripting example / tool to create a Functional Global with the user's choice of control. To create this subVI from scratch I have to create a case structure inside a single run while loop. No problems so far. I've even added the ability to pick a control from disk and add it to this new VI. The problem I'm having so far is creating a tunnel for my control from disk to pass its value thru. Any ideas on which methods will allow me to add a tunnel to a case structure? I'll be posting this example / tool to the CR when / if I get done with it. BTW, I'm trying to get all this in LV7.0 but I also have access to 7.1.1 if it has the solution. Thanks Chris EDIT: guess I should have looked a little harder, I found it. Simply use a "Connect Wire" method with the terminal of your choice and voila! Quote
