TreeView - strange lost of selection
For those who like to resolve strange bugs...
Here attached is a library where the main VI contains a Tree.
The "bug" is quite simple, I create a Tree with Cycles and SubFolders.
Each Cycle has a number of executions (written in the Tag and the Item of the Tree. Example "Cycle A - 5 executions").
Select a CYCLE, then change the number of executions (via the numeric control).
When the value reach 1, the Selection (of the ligne) is lost...
It's only when the value is above 2 that the Selection is kept!
I would be really happy if some of you would like to put an eye over this problem!
Thanks in advance.
Laurent
Download File:post-6600-1167924107.llb
The string you're generating for the Value of the tree is incorrect. When the value goes down to 1, the text you display in the tree is "Cycle A - 1 execution", but if you probe the string you're wiring into the Value property, it is "Cycle A - 1 executions". Since this is not a valid tree tag, no line is selected.
Also, I would recommend keeping an array of the tag names assigned to each row in the tree, and changing the Cell text for a row as it's changed, instead of re-writing the entire contents of the tree every time the number for a single row is changed.
-D
-D
OK! Here is the bug!
Nice to get a fresh mind on this kind of trouble!!! Thanks a lot.
(and by the way, I've posted this "bug" to NI via the support, as well...)
And thanks to the idea of keeping the array.
Cheers,
Laurent
