boonkeat Posted January 5, 2007 Report Posted January 5, 2007 hi all. i would like to ask how to capture still image from the webcam in a faster rate. currently it was capturing image around 2 second per shot using a unbranded webcam and saving the file with .BMP format i am using IMAQ USB function. 1.what is influencing the webcam capture rate? 2. what kind of spec i should look for when buying a webcam so that it wil capture in fast rate. Download File:post-7223-1167973147.vi Quote
alipio Posted January 11, 2007 Report Posted January 11, 2007 Hi The webcam, video compression and PC have influence in snap speed. Programming has a lot of influence, too. A producer/consumer scheme will improve speed, too. Using a logitech 4000 pro and a Pentium III -750 Mhz- I can capture almost 4 images per second, usin the attached vi- a modification or NI example for continous snap-. On a powerfull PC and a 5000 pro webcam, speeds are better. Try this vi. Webcam only needs to be initilizad once. Cheers Alipio Download File:post-6361-1168509410.vi Quote
