how to send continuous commands to COM Port?
pockey
Hi, all
I'm writing LabVIEW to test a board through COM Port.
There're buttons on the front panel for user to send commands to the board.
I could send one command at a time and display the response on a string indicator...
However, I did not know how to send continuous commands one-by-one with just one button.
For the "Reset" buttons, it will only send "x" to the COM Port, and the program runs OK.
For the "RX_LOWBAND" button, it should send string "p rxon1", "p paen0", "p hp0", "r 0x0118" and "r 0x24ad" one-by-one to the board and get each corresponding response.
I use a stacked sequence stracture to send these five commands one after one, however, the program could only implement the first one.
Since I'm quite new to LabVIEW, I do not know whether there's some easy way to realize that...
Could anyone give me some suggestion?
Thanks a lot!
Download File:post-6631-1168846857.vi
post-2-1168853441.gif?width=400
Hello,
I think you should consider a redesign of your code starting from one of the Design Patterns included with the standard templates. Depending on your knowledge of LabVIEW and application requirements you should go for a one loop state machine or consumer/producer pattern with 2 loops.
Also consider using events instead of polling buttons and do not forget your error handling.
Best regard,
Donald
Hello pockey,
Donald is absolutely correct... :thumbup:
I have moved my mouse considering Donald's suggestions and your requirement.
Result is a small piece of code which can guide in right direction.
I have used events instead of pooling and included error handling.
I am sure you can figure out remaining coding part...
All the best.
Regards,
Karthik SP
Download File:post-4779-1168870168.vi
