can Labview run on FoxBoard?
Ale914
  Quote
Cpu: Axis ETRAX 100LX
32 bit, RISC, 100MHz (100MIPS)
The short answer is "no", because LabVIEW does not currently run on that processor. However, you may be able to use the LabVIEW Embedded Development Module. This allows you to convert VIs into C code which you can then compile using the toolchain of your choice. The process is more involved because you have to create a cross-compiling toolchain and then make some VIs to tell LabVIEW how to use the toolchain and also port some of the LabVIEW C Runtime Engine to your target platform. Still, it should be possible.
