need to modify created bld
Hello all,
Actually i've created an exe that time i've created a bld file for that exe creation.
After that i modify some logic in the existing vis and built the exe again.Exe created successfully but the serial communication is not happening.for one command it is responding and for other commands it is not responding.Because of this issue exe has been built again with the previous bld file.it was working fine.
Now some new files are added to the project and tried creating the exe again, not with that bld.Exe created successfully again the same serial communication problem.Can i use the old bld file and modify it for the new files to create the exe.
If possible pls let me know how to modify the bld file.
Hello Supriyav,
Are you sure the problem is with .bld file?
Serial Communication is nothing to do with Old or new .bld files unless you change configuration.
Can you plz post your code(Dummy also works fine)?
All the best.
Regards,
Karthik SP
