slugger Posted March 2, 2007 Report Posted March 2, 2007 hi im using labview 6.1. i have a frame in a sub-vi that that reads 16 bytes from com7 (in my pc) into a global variable using a custom DLL. this variable is then used later to compare some data in another sub-vi. this was working fine for a day, then this morning i started it again and ran it. when i got to the point where this "read" happens i got a dr watson exception message. (i am running the application on nt4 in the development environment). after this point the gloabal had rubbish in it whenever i did a read, although it did also hold the basic read data. after a reboot etc it still did it. the fix was to completely remove this global from the application vi and my file globals.vi , create a new one and then use that in the same manner. everything was ok for an hour. then the same thing happened again. any ideas? this is really annoying. Quote
Michael Aivaliotis Posted March 2, 2007 Report Posted March 2, 2007 QUOTE(slugger @ Mar 1 2007, 10:58 AM) i am running the application on nt4 in the development environment NT4 like the one release in 1996? Ouch. Well, that's a tough one. It could be just the instability of everything. I would suggest replacing it with a functional global see here. Quote
