Set LVOOP Control via control reference?
I'm trying to spawn an asynchronous process that uses my LVOOP object (I'm actually using a Reference object from Tomi's example). I have an object that is a control on the asynch process VI and when I try to set its control value (using control references), I always get error 91. I've tried it using VI.SetControlValue method using Variant and Flattened String modes. Is there another way to do this?
Thanks in advance.
