Caius Posted March 15, 2007 Report Posted March 15, 2007 Hey all...!! I'm still leaning the intricacies of LabVIEW so forgive my Noobishness. I've created a VI that loads a .png file from a directory, then displays the image to scale with associated information. At present I'm having to manually input filenames or browse the directory for the image file. My question: Is there a way of listing all files from a directory (of images), selecting which one to use, so that it loads up. Alternatively can I simply scroll through the files of the directory in a similar fashion? Note: My eventual aim is to analyse spectrum images. Cycling through a list of file names and manually choosing to perform and record calculations for specific files is the goal of my VI. Caius LabVIEW 8.0 Quote
Mikkel Posted March 15, 2007 Report Posted March 15, 2007 I may be misunderstanding your question (if so, please correct me) but: You can use 'File Dialog' (*) component on the 'File I/O / Advanced File Functions' pallette - set the 'pattern (all files)' input to the string "*.png" to only show png files, set the 'start path' input to the path to your picture folder. In the LabVIEW Exampe Finder there are a lot of examples using file functions under 'Fundamentals / File Input and Output'. -Mikkel (*) Why this has to be an Express VI is beyond me, I hate it. :headbang: Quote
Caius Posted March 15, 2007 Author Report Posted March 15, 2007 Thanks. I'm giving that a try now. Edit: To clarify, I'm trying to list all file names on a front panel window, so that I can select one of the files for the VI to run with. Quote
