I've searched the LAVA and NI forums for this, but haven't found anything.
I'm trying to transition a LV2-style global to a queue. I have to admit that I'm quite inexperienced when it comes to queues, so I may just be making a stupid mistake.
In the attached snippet (LV7.1.1), shouldn't the output of the 'flush queue' be a 2D array of type double? That's what I would expect from the Labview help, which is the source of that text box in the diagram.
http://forums.lavag.org/index.php?act=attach&type=post&id=5527
What am I missing here?
Thanks,
Gary
QUOTE(ned @ Apr 16 2007, 02:23 PM)
  Quote
You can't have an array of arrays, so instead you get an array of clusters, with each cluster containing an array of doubles. The array elements in the queue could all be different lengths, so it would be impossible to merge them into one 2-D array.
I see. Thanks.
I was expecting it to just add a dimension to the input type.
