asharma Posted April 23, 2007 Report Posted April 23, 2007 hello, this vi is not running..its logic as to what this vi will do can be understood from vi itself. Quote
crelf Posted April 23, 2007 Report Posted April 23, 2007 QUOTE(asharma @ Apr 22 2007, 09:46 PM) this vi is not running..its logic as to what this vi will do can be understood from vi itself. Firstly - IMO that is a pathetic start to a thread - if you want our help, you're going to need to be a lot more descriptive and demonstrate to us that you're at least trying to solve the problem yourself. Your post doesn't even ask a question. What is it that you want? Do you want us to confirm that it doesn't work? If so, what does "doesn't work" mean? Secondly - you've got the indicators in the event cases that you're looking for the event change on - the "value changed" event never fires because the data never gets to the terminal - LabVIEW is a "dataflow" language, and you've achieved what is caled "thread lock". Thirdly, the fact that you did that suggests to me that you're very-much a beginner at LabVIEW, and frankly, that means that LAVA isn't the place for you. LAVA, as the acronym suggests, is for LabVIEW Advanced Virtual Architects - you will be much much more at home and get many more answers to your basic questions over http://forums.ni.com/ni' target="_blank">here. Once you've learned a lot and can proove that you've gotten some experience, you'll be welcomed back to LAVA. Quote
