BartS Posted April 25, 2007 Report Posted April 25, 2007 Hey, I am using LV7.1 and FileMaker8.5 that i connected with an ODBC driver. I only have problems inserting right after I opened FileMaker with ActiveX in Labview (I do this because FileMaker has to be running to be able to connect and insert to it in Labview), the second record I insert is no problem. The error code I get is : -2146824584. When I run the VI when FileMaker is open, there is also no problem (even the first record gets inserted). Any help is more then welcome Greetz, Bart Quote
Val Brown Posted August 31, 2007 Report Posted August 31, 2007 Did you ever get a solution to this? Also, what was the Connection String that you used to open the FileMake database? Quote
