DAQ Sampling Property in LabView
Does someone know how to get the sampling rate property of a task that is defined in MAX?
I'm using the sampling rate in my post test calculations and we've had issues were someone will change the sampling rate and forget to change the constant in the LabView program. If we could just pull the property from a tasks we could eliminate that error in our calculations.
You will find the sample rate, plus other interesting properties, by using a "DAQmx Timing Property Node". I had to right-click on it and "Select Filter..." to set it to display all. In 8.2 at least the Timing Property Node is found in the Measurement I/O -> DAQmx palette.
