How to lock LabVIEW Project folders' "arrange by" attribute
If you right-click on a file folder within a LabVIEW Project, you can select to "arrange by" type, name or path. This is all good an fun, however:
  • When you add new files to the folder the folder doesn't re-sort the list. You have to re-sort the contents manually every time.
  • There is no global setting for this. For example, newly created folders are not sorted in any controllable way.
This is bad.
I recently pointed this out to an NI Dev who is working on an improved Project view for a future release. They said they would try to resolve this issue. I agree it is very annoying as implemented now.
