Labview can create drop down in listbox
QUOTE(hink @ May 28 2007, 06:10 PM)
as the following picture
And next you'll want to have the color popup be available in a multi-column listbox ... :rolleyes:
Seriously, this is an area that requires a lot of programming to get that functionality. You can do it by capturing the mouse-click and then showing the proper popup on your own. You then have to use that popup's result and modify the listbox accordingly. I don't have any sample code, but if there is an ActiveX control that works for you, that might be the easiest.
David
