[Discuss] Vi, Vit, Ctl Icon and Description Editor
index.php?app=downloads&module=display&section=screenshot&id=13
File Name: Vi, Vit, Ctl Icon and Description Editor
File Submitter: LAVA 1.0 Content
File Submitted: 02 Jul 2009
File Category: LabVIEW IDE
LabVIEW Version: 8.0
File Version: 1.7.0
License Type: Creative Commons Attribution 3.0
Potentially make this file available on the VI Package Network?: Undecided
RUAG ICON Editor v1.7 - 14.11.2006
Copyright © 2006, Martin Hasler
This is the currend RUAG ICON Editor for LabVIEW 8.x
Have a lot of Fun with LabVIEW
Author:
Martin.Hasler
--see readme file for contact information
Description:
Copy the Files Icon.llb and RUAG-Icon-Editor.vi and description.txt into your LabVIEW 8.x/project/ Directory
If you start LabVIEW the next Time, the RUAG-ICON-Editor appears under LabVIEW Tools (Werkzeuge).
With the RUAG Icon Editor you can create or modify ICONS from Vi, Vit, Ctl.
The information about the ICON will be saved into the VI-Documentation.
=> First: Click "Load Directory"
=> Click "Tree-Control" to choose your VI to modify.
=> You can modify the colorsets by Editing the Color_Set.vi in the Icon.llb. Do not forget to click on: Save current values as default.
=> DO NOT USE THE FOLLOWING SINGN IN THE TITLE OR BODY!! §
=> Dobble -click your VI in the "Tree-Control" to open the VI.
Version History:
V1.0 The Original Version 1 was made by Pascal Helfenstein phelfens@fhzh.ch
V1.1 You can reload the old Icon.
You can Choose Color Sets.
Help button.
Changes will be saved into the VI documentation.
V1.2 You can Edit Icons in llb
You can Edit Icons from *.vit, *.ctl, *.vi
V1.3 The Pictures (New Icon, Old Icon etc.) are bigger
Bug Fixed that you have to press "Write Icon" twice for Vi's which are in a Project.
V1.4 More Documentation, (BD & FP) "Straighten the Code"
V1.5 "Edit Documentation" included
V1.5.1 Rearranged all Buttons. If you edit the Icon the first time, text=black, Title and Body= white
V1.5.2 If you edit a ICON the first time, a line feed will be added to the existing documentation.
V1.6 If the entered ICON text is too long it will be cutted automatically.
Automatically add and remove Tags < B > and </B> to the Description. (Preview included)
Rearranged Buttons
V1.7 An Indicator is blinking and the cursor is set to busy while the tree control is updated
Bug solved with old tree control paths
Automatically generate a Documentation with Username, Date, CTL Inputs and Outputs if they are connected to the connector pane (including their description)
Open Frontpannel and Blockdiagramm by right-click to the Tree CTL or LLB-Content
