fergy Posted June 14, 2007 Report Posted June 14, 2007 Has anyone of you ever used the Beckhoff Twin-CAT Software to control Stepper Motors (or DC-Servo) and sucessfully implemented it into Labview, to handle instructions ? I am looking into this configuration, but i have only two souces: one says yes, it's only little problem, the other says no.... Thank you, Greetz Ferg Quote
florache Posted December 27, 2007 Report Posted December 27, 2007 QUOTE(fergy @ Jun 13 2007, 02:03 AM) Has anyone of you ever used the Beckhoff Twin-CAT Software to controlStepper Motors (or DC-Servo) and sucessfully implemented it into Labview, to handle instructions ? I am looking into this configuration, but i have only two souces: one says yes, it's only little problem, the other says no.... Thank you, Greetz Ferg One approach would be to develop code for the Beckhoff PLC to control the steppers (KL2531 slice(s) required) and then use the Labview as an HMI to send high level commands to the PLC. In this configuration the PLC waits for Labview to populate a few memory locations with info such as direction of rotation, how many steps, a GO bit, etc. Once the GO bit is set, the PLC starts the motion and a Done Bit should be set when the movement has completed. I personally haven't done it but this would be my first approach. Hope it helps, Florache PS. 1. Are you thinking about a hardware or software PLC? 2. If a hardware PLC is usedwhat kind of communication interface do you plan to use? Quote
