How to Create or look up existing object
A (simple?) GOOP Q for anyone who knows this
I wish to create AN object with Endevo GOOP3 toolkit and then later on
create it again without having to check if it already exists so that I can get at the reference in another part of the program.
The Goop3 create method seems to indicate that this is possible since it has 3 choices.
1) Create
2) Create or look up existing
3) Look up existing
I wish to use 2)
Problem is I cannot figure out a way to tell that the ref already exists. I can see it when I use the objects in memory tool
but that is as far as I can get with it for now.
IS there a way to tell that the reference already exists in GOOP and can it be tested in the create Method that Goop3 makes?
I hope that was clear enough..
Thanks in advance for any replies.
J
