Running LabVIEW 7.1 on Fedora 2 & 3
QUOTE(Kalitexnis @ Jul 7 2007, 12:46 AM)
Hello,
I am using fedora 7 and labview 7 and when i type the tune2fs command on the console it says command not found.The strange thing is that i found the manual for that command. Can you think any reason why is this happening.
Many thanks in advance.
Are you sure you are logged in as "root"? You need to be superuser to use it...
Osvaldo
QUOTE(Kalitexnis @ Jul 6 2007, 06:46 PM)
tune2fs should be located in the /sbin folder -- Which you may not have located in your PATH variable. Try executing "/sbin/tune2fs" instead. (and as osvaldo mentioned, you'll need to be root)
  • 1 month later...
Many thanks for your reply,
Ive tried doing that and i recieved this message:
[root@ip-81-23-61-82 christos]# /sbin/tune2fs -O ^dir_index /dev/sda3
tune2fs 1.39 (29-May-2006)
/sbin/tune2fs: Bad magic number in super-block while trying to open /dev/sda3
Couldn't find valid filesystem superblock.
But it was succesfull for the swap partition.
Any ideas?
Regards
