Running LabVIEW 7.1 on Fedora 2 & 3
Hello,
I am using fedora 7 and labview 7 and when i type the tune2fs command on the console it says command not found.The strange thing is that i found the manual for that command. Can you think any reason why is this happening.
Many thanks in advance.
QUOTE(Kalitexnis @ Jul 7 2007, 12:46 AM)
Hello,
Are you sure you are logged in as "root"? You need to be superuser to use it...
Osvaldo
QUOTE(Kalitexnis @ Jul 6 2007, 06:46 PM)
tune2fs should be located in the /sbin folder -- Which you may not have located in your PATH variable. Try executing "/sbin/tune2fs" instead. (and as osvaldo mentioned, you'll need to be root)
  • 1 month later...
Many thanks for your reply,
Ive tried doing that and i recieved this message:
[root@ip-81-23-61-82 christos]# /sbin/tune2fs -O ^dir_index /dev/sda3
tune2fs 1.39 (29-May-2006)
/sbin/tune2fs: Bad magic number in super-block while trying to open /dev/sda3
Couldn't find valid filesystem superblock.
But it was succesfull for the swap partition.
Any ideas?
Regards
