Embedding HTML code?
crelf
Below the LAVA post editor is a "Post Options" pull-down menu. Select either of the HTML modes. Then just type in the HTML tags. I'm not sure if you need to turn off the rich text editor, by pressing the Toggle Rich Text Editor button in the upper right corner of the editor.
p.s. HTML tags are permitted only for premium members if I recall correctly. I'm not sure if Mike regards you as such. :D
What I did was following:
- Press toggle rich text button
- Set HTML On - Auto Linebreak Mode
- Paste embedded video HTML
- Press preview
<object width="425" height="350"><param name="movie" value="
name="wmode" value="transparent"></param><embed src="
type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
Where's the "toggle rich text button"? I tried doing what you said using the "toggle HTML source" button and it didn't work - do I need to click "Save HTML" as well?
Well look at that - it works! Thanks a bunch Ton - that little button in the top right was the one I was missing :thumbup:
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/watch?v=jxQSLEP1dZI"></param><param'>http://www.youtube.com/watch?v=jxQSLEP1dZI"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/watch?v=jxQSLEP1dZI" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
