MK07 Posted July 31, 2007 Report Posted July 31, 2007 Hi Friends, when i am trying to work with read and write serial port.vi (built in example) , i got the following error Error -1073807202 occurred at Property Node in VISA Configure Serial Port (Instr).vi> Basic Serial Write and Read.vi. This error code is undefined. aftertthat i couldn't communicate with com port.. actually i am trying to work with com1.. i am using labview development system 8.2 waiting for your valuable information.. with regards, Mk.. Quote
crelf Posted July 31, 2007 Report Posted July 31, 2007 Warning -1073807202 = A code library required by VISA could not be located or loaded. Do you have VISA installed? Upload your code so we can have a look at it. Quote
MK07 Posted August 1, 2007 Author Report Posted August 1, 2007 Hi, Thanks for your quick response. but i got the following error VISA: (HEX 0XBFFF001E) the specified state of the attribute is not valid, or is not supported as defined by the resource. actually i am using the example(serial port write and read.vi) program from labview8.2 , i am using evaluation version does it affect? waiting for your valuable information with regards, MK.. Quote
crelf Posted August 1, 2007 Report Posted August 1, 2007 QUOTE(MK07 @ Jul 31 2007, 01:40 PM) Quote i am using evaluation version does it affect? Do you have VISA installed? For issues with the evaluation version of LabVIEW, I stronly suggest you contact NI directly, or ask you question http://forums.ni.com/ni/board?board.id=170' target="_blank">here. Quote
