cluster size
No, but if your array consists entirely of fixed-size types (booleans, numerics, and clusters containing only those types), then you can use a typecast node to convert the array to a cluster without having to set the number of elements.
QUOTE(abuch06 @ Aug 9 2007, 10:12 AM)
http://forums.lavag.org/index.php?act=attach&type=post&id=6579''>http://forums.lavag.org/index.php?act=attach&type=post&id=6579'>http://forums.lavag.org/index.php?act=attach&type=post&id=6579
A typecast node coerces data from one type to another, so long as as the representations in memory are compatible. For example, you can take an array of U16 and typecast it to an array of U8 (the array length will be doubled), because a U16 in memory is stored identically to two consecutive U8s. See the help for more details.
