ardi Posted August 15, 2007 Report Posted August 15, 2007 my name ardi, i just apply to build a website that can use to measuring voltage and current via labview. in my mind, i just create a labview that measure the current and the people can change the voltage. but i doesnt understand how labview can publish that with interactive. Quote
Tomi Maila Posted August 15, 2007 Report Posted August 15, 2007 QUOTE(ardi @ Aug 14 2007, 09:41 AM) my name ardi, i just apply to build a website that can use to measuring voltage and current via labview.in my mind, i just create a labview that measure the current and the people can change the voltage. but i doesnt understand how labview can publish that with interactive. Ardi, welcome to the LAVA forums. LabVIEW has a feature called remote panels. With remote panels you can publish your VI front panels using LabVIEW web server. Remote panels are not to my knowledge included in all LabVIEW packages but they are included in at least LabVIEW professional that I'm using. Should you package not have remote panels, you can purchase remote panel support from NI as an add-on. As you didn't mention which LV version you are using, I assume you are using the newest release 8.5. Probably this is not the case. However in LabVIEW 8.5 there are two relevant items in the tools menu: Wbe Publishing Tool and Remote Panel Connection Manager. Both of these tools do what you'd expect. Use web publishing tool to publish your VI front panel on the web. You must enable LabVIEW web server from LabVIEW options as well and configure your local firewall so that they allow the traffic to LabVIEW web server. As a new member to LAVA forum, you should read http://wiki.lavag.org/index.php/Forum_Guidelines' target="_blank">LAVA guidelines. Tomi Quote
