sts123 Posted June 10, 2025 Report Posted June 10, 2025 Hi, I have this .vi project where I acquire data from the NI-Module and save it to TDMS. The acquisition rate for the TDMS is in the Resample Waveform block. However when I examine the TDMS in excel it does not match the expected number of samples recorded based on the chosen acquisition rate. I also tested it without the Resample Waveform block, when the rate is directly set in the Task, the TDMS again does not match the expected rate. Any thoughts? Regards R_R_9_single_channel_1.vi Quote
sts123 Posted June 10, 2025 Author Report Posted June 10, 2025 (edited) a Edited June 10, 2025 by sts123 Quote
