sts123 Posted June 12, 2025 Report Posted June 12, 2025 Hi I want to create a logic to trigger an event with Case Structure block with Greater Than block, where the "x" value for the Greater Than is input coming from one of the channels value. I used Get Waveform Components to extract the "Y" value from waveform and wanted to use this as an input into the "x" for Greater thank block, however Case Structure does not accept this type. Any thoughts? Quote
cordm Posted June 12, 2025 Report Posted June 12, 2025 You are trying to wire an array to the case selector. Extract the maximum value from the Y array using Array Max & Min. You might also want to take the absolute value of the Y array. Quote
sts123 Posted June 13, 2025 Author Report Posted June 13, 2025 Not sure if this is the right way of doing it. R_R_9_MTDS_Split_Rec_trig.vi Quote
cordm Posted June 13, 2025 Report Posted June 13, 2025 That is just the first value of the Y array, not its maximum. I assume you want to start the Hi_Rate_Trig task after reaching the threshold, right? Your VI won't do that, because the case structure executes once at the start when the boolean is still false. Get rid of the local variables and use data flow instead. Some more points: either wire a number of samples to read or a duration to the DAQmx Read VIs. That makes your waveforms the same length which makes postprocessing easier. Check what works with your resampling duration For continuous sampling mode, it is usually not necessary to wire the samples per channel terminal. labels keep the block diagram and front panel readable See if the attached VI does what you want. R_R_9_MTDS_Split_Rec_trig_CM.vi Quote
sts123 Posted June 16, 2025 Author Report Posted June 16, 2025 On 6/13/2025 at 11:55 AM, cordm said: That is just the first value of the Y array, not its maximum. I assume you want to start the Hi_Rate_Trig task after reaching the threshold, right? Your VI won't do that, because the case structure executes once at the start when the boolean is still false. Get rid of the local variables and use data flow instead. Some more points: either wire a number of samples to read or a duration to the DAQmx Read VIs. That makes your waveforms the same length which makes postprocessing easier. Check what works with your resampling duration For continuous sampling mode, it is usually not necessary to wire the samples per channel terminal. labels keep the block diagram and front panel readable See if the attached VI does what you want. R_R_9_MTDS_Split_Rec_trig_CM.vi 79.62 kB · 0 downloads This is great. Many thanks for your help. All makes sense. Quote
sts123 Posted June 16, 2025 Author Report Posted June 16, 2025 On 6/13/2025 at 11:55 AM, cordm said: That is just the first value of the Y array, not its maximum. I assume you want to start the Hi_Rate_Trig task after reaching the threshold, right? Your VI won't do that, because the case structure executes once at the start when the boolean is still false. Get rid of the local variables and use data flow instead. Some more points: either wire a number of samples to read or a duration to the DAQmx Read VIs. That makes your waveforms the same length which makes postprocessing easier. Check what works with your resampling duration For continuous sampling mode, it is usually not necessary to wire the samples per channel terminal. labels keep the block diagram and front panel readable See if the attached VI does what you want. R_R_9_MTDS_Split_Rec_trig_CM.vi 79.62 kB · 1 download Would it be possible, not to stop the recording of the low sampling rate, while the high sampling rate is also recording after the trigger? Quote
cordm Posted June 17, 2025 Report Posted June 17, 2025 Sure, just wire another button to stop those loops. Quote
sts123 Posted June 17, 2025 Author Report Posted June 17, 2025 5 hours ago, cordm said: Sure, just wire another button to stop those loops. Not sure if I understand... I want the loop when meets condition not to stop but carried on. At the moment there is an "OR" block that is connected to the LED and to the stop loop. Quote
cordm Posted June 17, 2025 Report Posted June 17, 2025 Sorry, I misunderstood. So when the threshold is crossed, the Hi_Rate_Trig task should start, but Hi_Rate_Volt should continue? There are plenty of ways to do that. One is to use a notifier for communicating from one loop to another. The loop that should be triggered waits for a notification, which the slow sampling loop will send when the threshold is crossed. The data and type of the notifier don't matter in this case. The triggered task can run multiple times, which may or may not be desired. A notification can also be send while the trigger task is running and it will then run again after it has finished. R_R_9_MTDS_Split_Rec_retrig_CM.vi Quote
sts123 Posted June 18, 2025 Author Report Posted June 18, 2025 Thanks for the .vi. Seem like the notifier is being passed to the new loop, as new .tdms file is created, but the loop inside the case structure is not being executed, hence the data is not being written into that file. The count stays at 0. Quote
cordm Posted June 18, 2025 Report Posted June 18, 2025 Use probes to check if there is an error: right click the wire and select "Probe" in the read loop. Do Hi_Rate_Volt and Hi_Rate_Trig use the same channels? You cannot run two tasks at once that use the same channels. Quote
sts123 Posted June 18, 2025 Author Report Posted June 18, 2025 12 minutes ago, cordm said: Use probes to check if there is an error: right click the wire and select "Probe" in the read loop. Do Hi_Rate_Volt and Hi_Rate_Trig use the same channels? You cannot run two tasks at once that use the same channels. They use the same channels. OK, thanks. Good to know I cannot run two task with same channels simultaneously. Quote
