viSci Posted 1 hour ago Report Posted 1 hour ago Experiencing strange behavior on a cRIO where I have a heater controller that uses 3 PID vi's. The execution properties of the PID vi's are set to Preallocated clone Reentrant. When running from the project the individual PID vi's do not initially open as clones. Only after opening the properties and then restarting do things start working properly. This is a repeatable issue that reoccurs each time the code is deployed to the cRIO from the project. I suppose I could just save the PID vi multiple times with different name but that is a poor solution and cumbersome since the PID vi is in the NI_PID_autopid.lvlib. Quote
