Getting active row in listbox
hi,
I'd like to be able to tell which row from a listbox was selected. This VI will run on a touch screen so the usual solution of using the double click event is not a good option. Instead I'd like the VI to tell which row the user chose after one press only (possibly adding a button if this isn't possible). What I have so far is attached.
thanks,
Jon.
QUOTE(spaceboy @ Aug 22 2007, 10:55 AM)
hi,
Starting in 8, there are VI Server Methods to return the row (and column for tables, trees, and multicolumn listboxes) from a mouse coordinate. Just capture the Mouse Down event on your listbox, then feed the reference and mouse coordinates to the method "Point to Row".
QUOTE(dsaunders @ Aug 22 2007, 09:04 PM)
Perfect! Thanks. :thumbup:
