darwhekar Posted September 4, 2007 Report Posted September 4, 2007 Dear All, I have to interface Fluke/Wavetek wt30x signal generator and HP 34401a digital multimeter in the simulation mode. I have been asked to design an experiment where frequency response of an amplifier will be plotted based on the input from the function generator. At the same time, for reading values generated by the function generator, HP 34401a DMM should be interfaced with it. However, this task should be accomplished using the respective instrument drivers in simulation mode. I have already configured these drivers in simulation mode using MAX and have created VIs for them. However, to interface these drivers to each other, I cannot find VIs that can read or write data from one instrument driver to the other. So, is it at all possible to interface instruments in simulation mode? Your help is highly appreciated. With regards, Amit Quote
