sVeNvAeTh Posted September 25, 2007 Report Posted September 25, 2007 I have to convert a string in a DBL. That is no problem, but the string uses decimal power, like 1.54 E+02. Now, I get the right value, but it only shows 1.54 and not the decimal power. What is the mistake? Quote
Donald Posted September 25, 2007 Report Posted September 25, 2007 QUOTE(sVeNvAeTh @ Sep 24 2007, 10:54 AM) Quote I have to convert a string in a DBL. That is no problem, but the string uses decimal power, like 1.54 E+02. Now, I get the right value, but it only shows 1.54 and not the decimal power. What is the mistake? The white space before the exponent is the problem... LabVIEW needs 1.54E+02. There are numerous ways of solving this. You could for example use "search and replace string " and replace '/sE+' by 'E+'. Quote
sVeNvAeTh Posted September 25, 2007 Author Report Posted September 25, 2007 i tried it, but it doesnt work. i still see the space between 1.54 and E+01. i insert a search an replace string and on left i put in the result string, the '/sE+' and the 'E+'. Quote
Mellroth Posted September 25, 2007 Report Posted September 25, 2007 QUOTE(sVeNvAeTh @ Sep 24 2007, 01:11 PM) Quote i tried it, but it doesnt work. i still see the space between 1.54 and E+01.i insert a search an replace string and on left i put in the result string, the '/sE+' and the 'E+'. Try searching for " ", and replace this with "" (without the qoutes). The search string "\s" (notice backslash), is the \-code view of a space character (To view any string in LabVIEW as \-code, right click on the string and select "\"-codes display) You should also wire the "Replace All" terminal with a TRUE constant, to get rid of all spaces. Good luck /J Quote
sVeNvAeTh Posted September 25, 2007 Author Report Posted September 25, 2007 Cool, that s what I need Many thanks!!! It works... Quote
