Recursive type structures for references
I'd really like to see support for recursive typing also outside LVOOP so that a reference type such as a queue could refer to the type that encloses the reference type. I see no reason why not to support such types. Reference types are not allocated at compile time so there would be no infinite memory allocations.
Example 1: Linked list
Typdef List.ctl
Element : I32
Queue : Queue of List.ctl
Example 2: Tree
Typdef Tree.ctl
Element : I32
Children : Array of (Queue of Tree.ctl)
Example 3: Recursive VI
VI Recursive.vi
Connector Pane
reference : Strictly_typed_VI of Recursive.vi
I tested this last case as I wasn't sure if this would work but it doesn't. The strictly typed VI reference on the connector pane doesn't act like a typedef so it doesn't update as VI connector pane gets updated. As a result when you browse for a connector pane type and select the VI itself, it uses a fixed connector pane before the connector pane change and doesn't dynamically update the connector pane change to the reference on the connector pane. Simple :)
Tomi
