new here, needing help on a mini project
Guys, i need help coding a user interface that receives signals from an i/o module such as wago originating from a switched on LED. Each switch represents a particular distress button in a particular shop which when pressed, switches an LED ON, CONVERTED into digital inputs in the user interface by Wago modules. This interface should be achieved by using LabView to create an interface consisting of a number of lightable LEDs relating to the number of shops in a mall, hence it should receive inputs that will enable the particular shops LED to light up and an adjustable alarm should sound and a small box with the name of the shop whose distress button has been triggered. Pls guys, i hope you help me out.
I'm assuming from the verbiage that this is a school/college/uni project that you want help with? If so, you should label it as such. Also, you'll find that you'll get a much better response if you show us what you've already tried so we can make comments on how to do it better or where you might be stuck. Otherwise, we might ge the idea that you haven't even tried and are just attempting to get someone to do your homework for you.
