.NET Control Callback fires intermittently
I have a set of VIs that implement the .NET MonthCalendar form to allow for date entry. I think I have found a bug in how LV registers for .NET events. My VI will work every time on the first call but it fails after 3-4 calls to the sub-vi. The problem seems to be that the .NET control is not registering it's DateSelected event every time, like it should.
See the attached zip file for an example. Give it a try and let me know if you figure it out or can at least reproduce my bug.
Download File:post-2411-1203050038.zip
Thanks,
-John
From NI Support:
I have filed a report (4ILAJ889) with R&D for further investigation. I
will update again you after the developers look into this issue. I tested
your application in LabVIEW 8.2.1 and did not see this problem, so I'm
assuming that something changed between LabVIEW 8.2.1 and LabVIEW 8.5. Are
you aware of the built-in LabVIEW calendar that you can select from with a
timestamp control? I'm still looking for a suitable workaround. Is it
necessary that the calendar pop-up? I'm sorry for the delay and I can
assure you that we are looking for a solution for you.
