dasrobie Posted March 1, 2008 Report Posted March 1, 2008 Friends has any one of you guys worked with Agilent 16751A logic analyzer module.I am unable to find the drivers for the device.Can you guys provide the drivers for this device. Quote
crelf Posted March 1, 2008 Report Posted March 1, 2008 Have a look around the NI Device Driver Network. Quote
dasrobie Posted March 4, 2008 Author Report Posted March 4, 2008 No my frend.I have tried searching through NI Driver network.but its not available there.Its a logic analyzer module.If any one of u guys have used it plz send me the drivers.It will be a great help. Quote
crelf Posted March 4, 2008 Report Posted March 4, 2008 QUOTE(dasrobie @ Mar 2 2008, 10:36 PM) No my frend.I have tried searching through NI Driver network.but its not available there.Its a logic analyzer module.If any one of u guys have used it plz send me the drivers.It will be a great help. Here are your options: Try to find a model that's similar in the NI Device Driver Network - often command prototypes are similar enough that you'll only need to make some minor changes to get your model up and running (sometimes you won't need to make any changes at all). Check out the other models in the Aglinet>Analyzer>Test section. Import a Plug&Play driver from Agilent. Contact Agilent directly to see if they have a version of the driver available Contract a profressional to write the driver for you (this may not be as expensive as you think, especially if they can use one of the other drivers as a starting point. Write it yourself and then submit it to the NI Device Driver Network for all of us to use. Quote
Niki Haines Posted March 12, 2008 Report Posted March 12, 2008 Hi! The 16751A can operate in a 16700 or 16900 series frame. <LI class=MsoNormal style="COLOR: navy; mso-list: l1 level1 lfo3">If the module is installed in a 16900 series frame, the system software can be downloaded from www.agilent.com/find/la-sw-download The system software contains the support for the modules. If the module is installed in a 16700 series frame, you can go to the following site to request a CD with the 16700 series system software. if you need a newer Logic Analyzer series module with faster state/timing speeds, differential support, etc you should go with the 16900 series Hope this helps If not please let me know Thanks and regards Niki Haines. Quote
dasrobie Posted March 15, 2008 Author Report Posted March 15, 2008 Thanks a lot. Hi! The 16751A can operate in a 16700 or 16900 series frame. <LI class=MsoNormal style="COLOR: navy; mso-list: l1 level1 lfo3">If the module is installed in a 16900 series frame, the system software can be downloaded from www.agilent.com/find/la-sw-download The system software contains the support for the modules. If the module is installed in a 16700 series frame, you can go to the following site to request a CD with the 16700 series system software. if you need a newer Logic Analyzer series module with faster state/timing speeds, differential support, etc you should go with the 16900 series Hope this helps If not please let me know Thanks and regards Niki Haines. Quote
