Reading issue on USB raw device
alexadmin
I try to operate with custom USB device based on FTDI FT245R chip. It works via VISA driver. I can succesfully write data to device. But reading causes some problems:
If reading performed when no data available from usb then reading count is 2 and data are 0x31 0x60.
If reading performed when data from usb present then reading count is two bytes more then real data present and first bytes are 0x31 0x60, next data is correct (from usb device).
This occurs in LabView while reading via "VISA Read" block as well as while reading in VISA Test panel.
What can cause this behavior? Any ideas?
